SC4+ as a DeviceNet Slave
Options
aginer
Is it possible to configure an SC4+ to act as a slave in a DeviceNet Bus?
What do you need to change in the EIO.cfg ?
Yes.
EIO_UNIT:
-Name "DNET" -Type "DNET_SLAVE" -Bus "CAN2" -Address "4" -Digin 128
-Digout 128 -Param "DNET_VAL"
See page 24 in I O plus.pdf attachedKevin Crosby - Propack0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
