COMException error workaround (other than rebooting the workstation)?
<P>Server stack trace: <BR> at RobotStudio.Services.RobApi.Win32.CoGetClassObject(Guid rclsid, CLSCTX dwClsContext, IntPtr pServerInfo, Guid riid)<BR> at RobotStudio.Services.RobApi.RobPlatformDesktop.{.cctor}b__0()<BR> at System.Lazy`1.CreateValue()</P>
<P>Exception rethrown at [0]: <BR> at RobotStudio.Services.RobApi.Win32.CoGetClassObject(Guid rclsid, CLSCTX dwClsContext, IntPtr pServerInfo, Guid riid)<BR> at RobotStudio.Services.RobApi.RobPlatformDesktop.{.cctor}b__0()<BR> at System.Lazy`1.CreateValue()<BR> at System.Lazy`1.LazyInitValue()<BR> at System.Lazy`1.get_Value()<BR> at RobotStudio.Services.RobApi.RobPlatformDesktop.CreateCommServer(String ipAddress, String systemId, RobCtrlType ctrlType, UInt32 netscanId)<BR> at RobotStudio.Services.RobApi.RobControllerConnection.{}c__DisplayClass6.{Connect}b__4(TaskCompletionSource`1 tcs, List`1 _)<BR> at RobotStudio.Services.RobApi.TaskUtils.{}c__DisplayClass1`1.{Run}b__0()</P>
<P>Exception rethrown at [1]: <BR> at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)<BR> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)<BR> at RobotStudio.Services.Controller.ControllerService.{WaitForConnectionAsync}d__44.MoveNext()</P>
<P>Exception rethrown at [2]: <BR> at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)<BR> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)<BR> at RobotStudio.Services.Controller.ControllerService.{StartAsync}d__3e.MoveNext()</P>
<P>Exception rethrown at [3]: <BR> at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)<BR> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)<BR> at RobotStudio.Services.Controller.ControllerService.{StartAsync}d__34.MoveNext()</P>
<P>Exception rethrown at [4]: <BR> at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)<BR> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)<BR> at RobotStudio.Services.Controller.ControllerService.{Start}d__2f.MoveNext()</P>
<P>Exception rethrown at [5]: <BR> at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)<BR> at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task)<BR> at ABBInternal.Controller.StationVirtualControllerManager.{StartLoadedController}d__d.MoveNext()</P>
<P> </P>
<font face="Verdana, Arial, Helvetica
- - I hope this post looks better on your browser than mine. nothing I attempt seems to make it prettier than this. whatever - -M. McGraw
<font face="Verdana, Arial, Helvetica0 -
So.. I get this error frequently ( 1 to 3 times a day ) usually occurs after closing a station and openning another. This error occurs and I get a station with no virtual controller. The system and virtual controller worked earlier, and I just got finished working in RobotStudio on the previous system .. so what causes the crash?
My current work-around is to shut down my workstation and re-start from cold. My workstation takes about 8 minutes to load-up the operating system and then I can try to load Robot Studio and open the station with the system that recently crashed. most of the time, the station and system run correctly. Occasionally I have to shut erything down a second time, (lather, rinse, cross fingers, repeat).
I hope there is a quicker solution somewhere.
M. McGraw
- 5.5K RobotStudio
- 396 UpFeed
- 18 Tutorials
- 13 RobotApps
- 297 PowerPacs
- 405 RobotStudio S4
- 249 ScreenMaker
- 2.7K Robot Controller
- 310 IRC5
- 59 OmniCore
- 785 RAPID Programming
- AppStudio
- 3 RobotStudio AR Viewer
- 18 Wizard Easy Programming
- 105 Collaborative Robots
- 4 Job listings
