TPWrite TPErase like old S4C+
Options
I have had numerous customers ask me if there is a way to write to the Flexpendant, and have it behave "just like the S4C+".
Is there a way to disable the screen displaying...
T_ROB1>>
T_ROB1>>
...to get the "normal" screen??? When you want to update a screen, (so TPErase, then TPWrite your data) it jumps back to the "T_ROB1>>" screen, scrolls all your written lines then jumps to the "actual" screen you want to display.
Also, using TPKReadFK kicks off 7 lines of your display! Any way to undo that???
Regards,
Mike
Mike
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
