Routine with parameters
Hi everyone!
I'm making an application with C# using PC SDK to work with virtual controllers.
One of the implemented features allows to load a routine and execute it from the application.
However, I wonder if it would be possible to execute a routine which needs parameters.
Can anyone help me?
Thanks in advance!
  • We also need to know about this .. thanks in advance.
  • No one? :(
  • Hi,
    This is not possible, since what you are doing with the SDK (similar to the Flex Pendant), you are moving the Program Pointer to a routine. The runtime can't figure it out the parameters at this point.
    Have you though about work around?
    - If the name of the routine always the same?
    - What type of parameters is expecting?
    Based on these two questions, you can have a routine without parameters that calls your target routine.
    BE
    Carlos Martinez
    ABB
