SystemBuilder.exe - Error: The program can't start because mfc120u.dll is missing from your computer
Henrik Berlin ✭✭✭
edited May 2015 in RobotStudio
Description:
The error message "The program can't start because mfc120u.dll is missing from your computer." appears when trying to start System Builder on some PCs after installation of RobotStudio 6.01 or 6.01 SP1.  The same (or similar) error appears when building systems using the function "Robot System -> From Layout".
Reason:
The required components have failed to install correctly.
Solution:
To fix the problem, you can locate and install the files manually. Locate the following file in the RobotStudio distribution and run it:
RobotStudio\ISSetupPrerequisites\{3A302466-01DB-4D60-8604-39AD555BB541}\vcredist_x86.exe
Alternatively, you can download the file from Microsoft:
http://www.microsoft.com/en-us/download/details.aspx?id=40784
Press "Download" and select the file "vcredist_x86.exe"
The problem will be be resolved in the next version of RobotStudio.
Kind regards,
ABB
  • If i come across anything else I'll be sure to post :)
  • This problem has been fixed in RobotStudio 6.01.01 that is now available for download.
    ABB
