add option for virtual robot
newform
Dear All,
Can you tell me how to add controller options to a virtual robotic system? We created a virtual system from a template in RobotStudio. But only standard options are included. Other options such as "World Zone" is not available.
Can anyone help us?
Many thanks
Can anyone help us?
Many thanks
Hi,Go to the offline tab, then start the system builder.From the system builder you can modify an existing system, but since you are using a template system it would probably be better to create a new system (or at least make a copy and then modify the copy).Use virtual keys, then when you get to the modify options page select the options you require, make sure you select the correct robot (see screen shot) so it will load the correct robot model.More info is available in the help (press F1).Hope this helps0
Dear Graeme,
Thank you a lot for your detailed answer.
My mistake was that I didn't copy a template before modification.
Thanks again for your help.
This discussion has been closed.
- 88 OmniCore
- 42 AppStudio
