AutoConfiguration greyed out in 5.12.01
sturner
Im experiencing the same problems in 5.12.01...
AutoConfiguration is greyed out and can only perfom configuation for individual targets.
anyone else getting this?
hiI have justed been looking if i had the same problem but that is not the case.I can perform autoconfig for both individual tagets and for a hole path.Kent zibrandtsen
Hardi International A/S
Denmark0 -
The problems comes and goes.Restarting RobotStudio brings it back again but this is becoming frustrating and time consuming!This problem was supposed to be fixed in 5.12.10 -
hi
Is it possibel for you to make a pack & go then i will try opening it in my RS,then we will know if it is the station that is the problem or something else.
Kent zibrandtsen
Denmark0 -
Hi,Please get in touch with our technical support about this issue.Kind regards,Henrik Berlin
HiYes I will report this problem... It appears this problem may occurr when AW PP has been opened and allthough I am aware that configuration can be done within the powerpac I need to go back to the home tab to copy and apply target orientations at times so trying to use the AutoConfiguration here is better than using the PP0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
