Upside Down Robots
I have a system with an inverted robot (mounted on a gantry).
The floor level in robotstudio is above the robot because of this, I can correct this using task frames, but then i am unable to rotate the station to view it up the correct way. If i view it up the correct way i get strange view clipping occuring, and you can't select things when looking "through" the floor. View attached to show the problem.
Any Suggestions
Hi friend,I understand your problem, I think you need to shift the entire setup above to the floor level and then adjust the base frame. By adjusting the base frame everything will get re-setted and your function will work normally. Hope this will help you.Regards,
Nikhil0
- 348 IRC5
- 847 RAPID Programming
- 21 AppStudio
