Weavedata speed issue
Hi all,
I am having a problem with setting the speed of a weave in ArcWare.
The problem that I am finding is that the speed data in the welddata does not control the speed of the weave for some reason.
Is there a way to set the speed of the weave movement in ArcWare?
Any help would be much appreciated.
Ken
Ken
  • I have a similiar issue, i believed it to be a mechanical / servo motor issue as i have a large gantry mounted robot that does not weld at the correct speed in weave types 0 and 1, changing to rapid weaving does make it travel at the correct speed, but the robot does not accurately weave.
    Am still waiting on a solution for this problem from ABB
