Powder coating application
NIKHIL
Hi Friends,
Can any one help me to find out whether IRB 6400/2.8 with 120kg payload and with S4C controller robot can be used for Powder coating application ??
Regards,
Nikhil
Nikhil
Hello,IRB6400 is developped for general purpose.therefore You can use it for all kinds of application.But you need to confirm some factors before you apply it to the application.For instance, Arm length, Payload(handling capacity) and so on.Of course there is a possibility that the coating application requires certain option software.To check it out is the first step, I think.BR,0
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
