err. 33417
have you ever faced with err. 33417?
we checked all parts, no clue...
could be smd?
s4c+, irb2400
Hi33417: Transmission error mea
Error in measurement system %d
at connector board %d when test-
ing seriel link in normal mode.
Check:
- Check configuration of
MEASUREMENT_CHANNEL
- Check seriel link
- Check/Replace measurement
board(s)
- Check/Replace Axis Computer
boardRegards
Knud Erik Lindberg
Danrobotics0 -
thx for the quick reply.we changed smb and smb connection cable..nothing has changed...axis board?0
Try to change axiscomputer
Regards
Knud Erik Lindberg
Danrobotics0 -
In general, the error occurs when those parts are broken. (AXC, SMB, SMB cable)
If you have already replaced all parts, and the robot is stil in faulty,then there must be a sort of disturbances between AXC and SMB.The last thing to do is to check all connections.BR,0
