increment NumericUpDown by button
Is it possible increment and decrement Value in component NumericUpDown by two buttons in ScreenMaker 5.12.  One button is for increment and second button is for decrement NumericUpDown.Value.
Radim
  • Hello Radim
    NumericUpDown has always a scroll bar to select the values and always you can give your value limits from the properties of the NumUpDown control in Screen Maker. Could you please elaborate what is the necessicity to put additional two controls (Button) into the screen to do scroll up and down. Exactly mention the type of binding mechanism you are loking at.
    This may be possible through multiple states properties of a button.We need to find a workaround after your clarification.
    Regards
    sunil sabut2009-09-01 07:54:31
    Sunil Sabut
    India Corporate Research
    ABB - India
