power cable for additional encoder unit
carmila
Dear All,
I have a single cabinet IRC 5 and I use 1 digital IO unit and 1 conveyor tracking. Now, I'm going to add 1 more conveyor tracking on it. But, I'm confuse, because there is only 2 available power cable. and there's no left for the additional conveyor tracking. Can I still use this additional conveyor tracking? And how to connect to the controller?
Thank you
Thank you
indah carmila
I found that there are 2 available connectors ( contain 5 cables -- A35.x1). And 2 used connectors ( I/O 2.X5). I use 2 I/O 2.X5 directly to my digital IO (DSQC 652) and 1st queue tracker. Can I use the A35.x1 to my 2nd queue tracker ? ( For queue tracker there are x5 and x3. The x5 contains 12 pins, and x3 contains 5 pins. If I connecting the A35.x1 (5 pins) into the X5, and connecting the other pins (7 pins) to the jumper cable (for make the unique address), Can it works?
Thanks a lot.
BR,
Carmila
indah carmila0 -
Dear all,
FInally I can connecting the third queue tracker via cable A35 x1. It's work.A?
Thank you
indah carmila0
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
