open new Screen
radim
private void btRollDoors_Click(object sender, EventArgs e)
TpsRollDoors windowTpsRollDoors = new TpsRollDoors();
windowTpsRollDoors.Show();
I created 4 screens for Flexpendant in Visual Studio 2008. I created button. I want to open by buton new window. I download the files to Home directory and tested. But it did not open new window. I close the main window but did not open new window. Could you write me program code C#. How to open new window from Event method for button.
Here is my program code for Event method:
Thank you for answer.
Radim
Hi,You have to use the method ShowMe. Examples are available in the RAB Help ..BRCarlos Martinez
Hi,i've installed visualstudio 2008 and sdk 6.08.I've tried to open a new view called "TpsControl1", but I do not have a "showme" method.Does anyone know why?Tnx
Ok, the empty view isn't a form, so it's normal that "showme" method doesn't exist.But for empty view.. how can I change page? the show method doesn't work.0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
