Problems.
To all RS 3.0 users.
If you work with Workobj with robhold true and tools with robhold false' there is a error. If you edited your workobj the dialogbox set robhold to false. i you say OK your workobj wil deatchaed your robot and parent will be workobj0. If you then try to attached it witk drag and drop i browser your targets wont fit.
If you rotate your tool with robhold false the tooldata will not be the same in the robotprogram. rotate your tool or workobj directly in the robot to get it to fit in the reel world.
It took hours to find out what was wrong.
Abb has located the same error but will first fix it in the next relees.
A got advice. DON'T UPGRADE TO 3.0 IF YOU HAVE A 2.1 THAT WORKS
No regards this time
Klaus
Klaus Soenderhegn
www.cadalysator.dk
Dear Klaus,
We are looking into this and will get back to you as soon as possible.
Best regards
/Ulrika Mor?n
Support Engineer
- 304 PowerPacs
- 355 IRC5
- 850 RAPID Programming
- 26 AppStudio
