Convert Float into Integer
Ahmad
Hello everyone
Can anyone please tell me how to convert float number into integer number in RAPID (RobotStudio).
For Example if ==> nPassOffs_Y:= ((2-1)/4) = 0.25 then i only need the 0. I jsut want to drop the decimal part. IS THAT Possible in RAPID?
Thanks in advance
Ahmad
Hi Ahmad,Use the Truncate function:nPassOffs_Y:= Trunc((2-1)/4);ornPassOffs_Y:=Trunc(nPassOffs_Y);BR,Shane0
Thanks Shane for your helpI will try thatthanks agianAhmad????0
you can use "trunc" to convert to interger (or use "Round" if you need a rounded number) .Or you can also use DIV for integer division.nPassOffs_Y:= ((2-1) DIV 4)0
