Assertion Fail when Tpu is started
I canA't work with the teach pendant <?: prefix = v ns = "urn:schemas-microsoft-com:vml" />of the Quick Teach, when it start is produce a assertion fail and no is possible do nothing.
You can see the fail in file. The version QuickTeach is 5.5. Copilacion 2461.
You can help me?
Thank you
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
webwiz/3093/Assertion_failed.JPG
Hello,Try the same system, but with new key.id.In Virtual Robot Browser:- Select system- Click Properties- Click Finish=> A new key.if file is generated.Hopefully this will solve the problem so now try the system again.If not, try to create a new system and try with that one.Best regards,Anders Jahnberg, ABB RoboticsBest regards,
Anders Jahnberg
ABB Robotics0
- 858 RAPID Programming
