RunRountime
imageimageI want to use a rapid routine in manual Mode.
When I select press the routine I get first the message "the robot may move .." thenI press Yes and I get this message:
Do you know how I can run a routine with screen maker.
  • Hi
    Ensure that you set "Program Pointer (PP)" to the Routine you are trying to Run
    Note :
    In flexPendant Go to - ABB menu - Program editor - Debug - set PP to Routine and then select your routine from the list. After setting PP , then try to run the routine from the Screen Maker window.
    Regards
    Sunil
    Sunil Sabut
    India Corporate Research
    ABB - India
  • Hi,
    i set the PP to the routine. I still have the same issue.
    When I select runrountine  with screenmaker I get this error message.
    regards
  • Kindly attach your project to this forum in zip format. we will suggest you accordingly.
    Are you working on Real controller or Virtual controller ?
    What is the RW version of your system ?
    Regards
    Sunil
    Sunil Sabut
    ABB - India
  • webwiz/3104/UserInterface1.zip
    webwiz/3104/44-52997.zip
    I m working on Virtual controller
    I use Rw 5.12.02
  • Could you check if your system has a system module called ScreenMaker.sys?
    Carlos Martinez
    ABB
  • Yes I have ScrennMaker.sys in my system
    Regards
  • Your file "webwiz/3104/44-52997.zip" has another two systems.
    I looked in the three systems (including backups) and it seems that ScreenMaker.sys is not loaded.
    - Could you load/reload the module ScreenMaker.sys  and the config file. I am attaching a copy of them
    webwiz/2219/SM_test_files.zip <- These files are supposed to be installed in your system automatically. USE THEM ONLY for this test, since new versions might be different.
    Carlos Martinez
    ABB
  • The Screenmaker.sys was not loaded.
    Everything is fine now.
    Regards
