RunRountime
fertil
in ScreenMaker
I want to use a rapid routine in manual Mode.When I select press the routine I get first the message "the robot may move .." thenI press Yes and I get this message:
Do you know how I can run a routine with screen maker.
HiEnsure that you set "Program Pointer (PP)" to the Routine you are trying to RunNote :In flexPendant Go to - ABB menu - Program editor - Debug - set PP to Routine and then select your routine from the list. After setting PP , then try to run the routine from the Screen Maker window.RegardsSunilSunil Sabut
India Corporate Research
ABB - India0 -
i set the PP to the routine. I still have the same issue.
When I select runrountine with screenmaker I get this error message.
regards
Kindly attach your project to this forum in zip format. we will suggest you accordingly.Are you working on Real controller or Virtual controller ?What is the RW version of your system ?RegardsSunilSunil Sabut
ABB - India0 -
webwiz/3104/UserInterface1.zip
webwiz/3104/44-52997.zip
I m working on Virtual controller
I use Rw 5.12.02
Could you check if your system has a system module called ScreenMaker.sys?ThanksCarlos Martinez
Yes I have ScrennMaker.sys in my system
Regards
Your file "webwiz/3104/44-52997.zip" has another two systems.I looked in the three systems (including backups) and it seems that ScreenMaker.sys is not loaded.- Could you load/reload the module ScreenMaker.sys and the config file. I am attaching a copy of themwebwiz/2219/SM_test_files.zip <- These files are supposed to be installed in your system automatically. USE THEM ONLY for this test, since new versions might be different.Carlos Martinez
The Screenmaker.sys was not loaded.
Everything is fine now.
Regards
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
