number of joints
Newbe
When I start a new station with any robot that is not a 6 axes robot I get the below error for that robot, in this case it was the IRB660_250_315_01_2 model. Can anybody tell me why that is or is that normal?
IRB660_250_315__01_2: The number of joints is different between the library model and the controller configurations. 10/19/2009 7:20:21 PM General
From the RobotStudio Release Notes:
Error message starting system with IRB260/660
Starting a system with IRB260/660 gives you an error message: "The number of joints is different between the model and VC". The reason is that the IRB260/660 is modeled with six joints in RobotStudio of which two are locked, but has four joints in the VC .Henrik Berlin
thanks Henrik, just wanted to make sure I was not doing something wrong...
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
