Screen Recorder is not selectable
Winos
< ="-" ="text/; =utf-8">< name="ProgId" ="Word.">< name="Generator" ="Microsoft Word 11">< name="Originator" ="Microsoft Word 11">
Hey,
I want to record a simulation with the screenrecorder. All record buttons are
inactive. I the previous version of RS was a link in setting-menu to Microsoft.
I don?_Tt have a clue what encoder, codec or whatever I have to download and to
install to use this recorder.
Thx for you help
Wilfried
Hello Wilfried,When I first started up RS my screen recorder buttons where inactive as well. To active them I had to go into RS options and setup the ScreenRecorder options. Have you already done this? If not try that and see what happens.Good Luck!RickRick Lemberg0
Hey,Tank you, I ve checked this before, BUT I have not seen, that no codec was selected. Now the recorder works !
Thank you !W.0
This discussion has been closed.
- 365 IRC5
