Screen Recorder is not selectable
  • Hello Wilfried,
      When I first started up RS my screen recorder buttons where inactive as well.  To active them I had to go into RS options and setup the ScreenRecorder options.  Have you already done this?  If not try that and see what happens.
    Good Luck!
    Rick
    Rick Lemberg
  • Hey,
    Tank you, I ve checked this before, BUT I have not seen, that no codec was selected. Now the recorder works !   Thumbs Up
    Thank you !
    W.
This discussion has been closed.
