Sync rapid wobj definition to modelling
Laro88
Is it possible to import wobjdata defined in a Rapid module ( offline ) into the modelling designer?
I generate several program and system modules with various declaration inside, and would like to inspect these visually in the modelling tab.
It seems like there is no sync between Rapid and modelling although it is done in the same project.
Only data that is referenced from a move instruction is synchronized. To ensure your data is synchronized, you must use in in an instruction, MoveL, say.Henrik Berlin
Thank you Henrik, that explains the "missing linking"
I will go generate some references :-)
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
