IRC5 Motors On Emulation
rwooden
I need to emulate the motors on button. I need to add another or remote motors on button to my system. How can I alias or use the existing input signal to do this. As well as using the existing light output signal on my new button.
Robert
Hi, may be you can try to use System Input (one input signal can trigger some system actions): configuration => System Input => Show all => Add => Signal Name => choose "Motor ON and Start"
I hope it can help
BR
Dhyan
fear of GOD is the beginning of wisdom0 -
Thank you for the info, I will give it a try.Robert0
- 367 IRC5
- 858 RAPID Programming
