Create new wobjdata
Laro88
I need to create a new wobjdata with an offset and a rotiation. Is there any convenient way to do this in Rapid?
Basically I have a wobjdata (wobjC ) coming from a calibration session, that I need to create a new wobjdata from ( to make the program simpler to understand) I need to move the wobjC a bit in the X and Y direction and rotate it 180 degrees around Z.
Is there any convenient way to do this?
copy the wobjdata you have.Use the copied wobjdatamodify the components of the copied wobjdata.and execute your commands or instructions as per the edited "copied wobjdata".Lingaa0
This works fine in RobotStudio, however I needed to do so in generated RAPID code:
Please note that this just copies a a wobjdata and modifies the oframe stuff. Ideally I would like to compute a "fresh" wobjdata as the sum of the old wobjdata and the oframe stuff. However this requires a proper 3D Vector Api ( I will use Microsofts Media3D namespace to do this at some point in time )
However, In C# the construction of a new wobjdata looks like this.
//Create tobjdata variable for the rap polishing program
RapidData rd_woCalibLathe = controller.Rapid.GetRapidData("T_ROB1","MSystemVars","woCalibLathe");
WobjData woCalibLathe = (WobjData)rd_woCalibLathe.Value;
//System.Windows.Media.Media3D.Vector3D v3d = new System.Windows.Media.Media3D.Vector3D(woCalibLathe.Uframe.Trans.X
WobjRapProgram = woCalibLathe;
WobjRapProgram.Oframe.Trans.Z = (float)DistToLathe;
Orient o = new Orient();
o.Q1=0.5;
o.Q2=0.5;
o.Q3=0.5;
o.Q4=-0.5;
WobjRapProgram.Oframe.Rot = o;
this.WriteToModule("PERS wobjdata wobjRapProgram:="+WobjRapProgram.ToString()+";");
Hi,Perhaps the posting inmay provide some inspiration.Henrik Berlin
ABB0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
