IRC5 Motors On Emulation
I need to emulate the motors on button.  I need to add another or remote motors on button to my system.  How can I alias or use the existing input signal to do this.  As well as using the existing light output signal on my new button.
Robert
  • Hi, may be you can try to use System Input (one input signal can trigger some system actions): configuration => System Input => Show all => Add => Signal Name => choose "Motor ON and Start"
    I hope it can help
    BR
    Dhyan
  • Thank you for the info, I will give it a try.
    Robert
