Create new wobjdata
I need to create a new wobjdata with an offset and a rotiation. Is there any convenient way to do this in Rapid?
Basically I have a wobjdata (wobjC ) coming from a calibration session, that I need to create a new wobjdata from ( to make the program simpler to understand) I need to move the wobjC a bit in the X and Y direction and rotate it 180 degrees around Z.
Is there any convenient way to do this?
  • copy the wobjdata you have.
    Use the copied wobjdata
    modify the components of the copied wobjdata.
    and execute your commands or instructions as per the edited "copied wobjdata".
    Lingaa
  • This works fine in RobotStudio, however I needed to do so in generated RAPID code:
    Please note that this just copies a a wobjdata and modifies the oframe stuff. Ideally I would like to compute a "fresh" wobjdata as the sum of the old wobjdata and the oframe stuff. However this requires a proper 3D Vector Api ( I will use Microsofts Media3D namespace to do this at some point in time )
    However, In C# the construction of a new wobjdata looks like this.
    //Create tobjdata variable for the rap polishing program
    RapidData rd_woCalibLathe =   controller.Rapid.GetRapidData("T_ROB1","MSystemVars","woCalibLathe");
    WobjData woCalibLathe = (WobjData)rd_woCalibLathe.Value;
    //System.Windows.Media.Media3D.Vector3D v3d = new System.Windows.Media.Media3D.Vector3D(woCalibLathe.Uframe.Trans.X
    WobjRapProgram = woCalibLathe;
    WobjRapProgram.Oframe.Trans.Z = (float)DistToLathe;
    Orient o = new Orient();
    o.Q1=0.5;
    o.Q2=0.5;
    o.Q3=0.5;
    o.Q4=-0.5;
    WobjRapProgram.Oframe.Rot = o;
    this.WriteToModule("PERS wobjdata wobjRapProgram:="+WobjRapProgram.ToString()+";");
  • Hi,
    Perhaps the posting in
    may provide some inspiration.
    ABB
