How to run the Virtual Flexpendant ??
biozard
HI!
Yesterday I downloaded robot studio 5.12.02 because I want to learn something about the Abb irb 140. The problem is that I cannot open the virtual Flexpendant. I installed the robot application builder and many other applications wich where with the program but I cant open it.
What must I do to open the Flexpendant?
Dear biozard,The Virtual FlexPendant does not come with Robot Application Builder. It is a part of RobotStudio. So I will move this topic to that forum.But to answer your question. In RobotStudio you need to first start a Virtual Controller, then you can start the Virtual FlexPendant.So try this:Start RobotStudioIn the top left corner click the RobotStudio menu and select [New Station]Select the default system for IRB140 that you are interested in and click [OK]Wait for the controller to start and you see the green light in the bottom right corner.Then on the [Offline] tab, you can select [Virtual FlexPendant]If you then have any problems you should take screenshots of them and post them describing which step had the problem.John
Developer Center0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
