Run Time Erro
when I tried to start my Visual Controller I got these erro message
"Run time erro !
Program: C:PROGRA~1FELLES~1ABBAUT~1INTELL~1INTELL~2.EXE
abnormal program termination"
and my VC should be shut down in 5 s. this happen with all my VCs.
Is there any body know what is happen here?
Xin-H38517,3716435185
I would try to unregister and re-register Interlink, i.e. Interl~2.exe.
To unregister Interlink:
Click the Start button on the task bar and select Run. Type or browse to the path of the InterLink.exe file followed by the -UnRegServer command line argument. For example:
C:Program FilesCommon FilesABB AutomationInterLinkinterlink.exe -unregserver
To re-register:
click the Start button on the task bar and select Run. Type or browse to the path of the InterLink.exe file followed by the - RegServer command line argument.
For example:
C:Program FilesCommon FilesABB AutomationInterLinkinterlink.exe -regserver
Russell Drown0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
