soldering information
any body of u give any sample programs regarding soldering using 2400 or any related information?
In terms of offline programming I guess you should be able to benefit from using ArcWelding PowerPac. You can define you own soldering-specific instruction templates and use in your programming with ArcWelding PowerPac.As for the application as such I give not give any advice as I am not an application expert. Perhaps someone reader of the "General" discussion forum can? (Moved it to the General Forum)Henrik Berlin
ABB0
