SM 5.12.02 does not work
wolfino
in ScreenMaker
After uninstalling all the previous versions and installing the new version of screen maker I get this error if i want to run it.
You can try this :Uninstall any existing version of Robot Application Builder.Install released version of Robot Application Builder 5.12.02.And then launch ScreenMaker.0 -
It works.Thanks0
the current ScreenMaker 5.12.02 and RobotStudio 5.12.03 does not work (RAB 5.12.02 is installed).
The building and deploying works fine, but the virtual flexpendant gives errors:
See the post present on this link. Looks like you are missing a FlexPendant Interface option in your system.0 -
when i try to create a new system based on a template (with the FlexPendant Interface option), i get this error message (tried different manipulators):
Seems that some libraries are missing (or not found).
apox2010-01-12 14:36:280 -
Hello,Can you post your previous query related to 'IRB_ELBOW_BASE' in the RobotStudio IRC5 (5.x - ) forum (http://forums.robotstudio.com/forum_topics.asp?FID=13)0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 31 AppStudio
