Start up time application.
Rob(ot)
in ScreenMaker
I have a the latest Flexpendant SxTPU version 3,, but still to start-up my screen maker application, it takes up to 15 to 20 seconds.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The application is about 600 kb,
Is there a solution for this problem??
Thanks in advance
Hello,Would it be possible for you to share the application you are referring to, so that the problem can be analyzed.Thanks0
HiIt depends upon the type of application you built ( data binding mechanism involved in your scree maker project). Flex Pendant -3 is having enough resources to handel comparably larger customised applications compared to flexPendant-2. Please look into your screen maker applications and see how complex it is and look for the opening time in FP.RegardsSunilSunil Sabut
India Corporate Research
ABB - India0 -
[QUOTE=Abhishek PM]Hello,Would it be possible for you to share the application you are referring to, so that the problem can be analyzed.Thanks[/QUOTE]
Hi according to me your hardware configuration is not sufficient for this software i mean your configuration is low comparison for this and one of think more virus have in system. remove all
i hope you are agree.
Good luck
harry1472010-03-15 10:47:040
