Face geometry not moving with part or body?
Kevin
RS 5.12.02
webwiz/40/WireTest.zip
The Pack&Go station has a box located at 0,0,0.
I start the 'WireTest' add-in under 'VSTA User Add-ins', then click the 'WireTest' button to launch 'Form1'.
I then select the top face of the box and click the 'Create Wire' button. The wire appears as expected on the selected face.
I repeatedly undo to restore the station to its original condition, then move the box to 0,0,100.
Now I repeat the procedure to create a wire on the top face of the box, but it appears below the box where the face was originally located.
Is this a bug, or have I done something stupid in my add-in code?
Thanks,
Kevin
Thanks,
Kevin
Hi Kevin,
I think this works as it should.
CreateParametricCurve() works in the local coordinate system, so the transform of the box has no effect. Since you add the created body to myPart which has a zero transform, it will end up in a different place.
regards,
Johannes
Johannes Weiman
Thanks for the explanation Johannes,
Kevin
Johannes
I have this problem too, when I load a geometry, and move it to a position for example (0.2,0.2,0.2), I want to get some points on one of the edges, so I use "body.shells[0].wires[0].coedges[0].edge.GetPointAtParameter()", all the points appear in the place where the geometry was load; you have explaind it works in the local coordinate system, but can I set it works in world coordinate system? can we resolve this problem? I just want to get the points on the gometry after the moving, and then I can create target on the edge:thank you very much
in robotstudio4 API. there is a funtion called "createtargetoncurve", it exist in robotstudio5 API? I don't find it;
best regards0 -
Johannes
best regards0
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
