FP SDK - NumPad
Hi!
I'm trying to implement a numpad in a flexpendant application, but since I'm quite new to<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
this I wonder how to implement it? The manual just mention something about connecting the pad to a textbox?
BR
B Axel
John Wiberg2011-10-04 14:08:29
  • I gave up and used a CompactAlphaPad instead, but still I'm curious how to use the NumPad.
    // Axel
  • Someone know how to use it ?
    I can't see the numpad on my form !!
    [VS2008 + FlexPendant]
  • Got the same problem, can't see the NumPad on the form.
    In an older version i used two years ago(I think RAB 5.11) it works ...
    Anyone info's about that?
  • Got the same problem..
    How to use NumPad control??? there are too few documentation about it in the FP SDK (v5.14).
    It's can be used only with TextBox target??
  • I have used the NumPad function till v5.13 and it worked in the following way:
    Declaration of the NumPad - in my case NumPad_Joints and then I connected
    the target of a TexBox (see last command) with the NumPad
    this.numPad_Joints = new ABB.Robotics.Tps.Windows.Forms.NumPad();
    this.numPad_Joints.BackColor = System.Drawing.Color.White;
    this.numPad_Joints.EnablePoint = true;
    this.numPad_Joints.EnableSign = true;
    this.numPad_Joints.ExponentFormatButton = false;
    this.numPad_Joints.Location = new System.Drawing.Point(331, 29);
    this.numPad_Joints.PointText = ".";
    this.numPad_Joints.Size = new System.Drawing.Size(191, 191);
    this.numPad_Joints.TabIndex = 33;
    this.numPad_Joints.Visible = true;
    numPad_Joints.Show();
    numPad_Joints.BringToFront();
    this.numPad_Joints.Target = this.tb_NumPad;
    Maybe it helps you.
    BR/
         Chaos
  • Tnx Chaos about your help!!
    but I have another question: How I can do it as screenshot?? (is "Program Data" edit num value).
    If the numpad target can be only a texbox, how we can do it about listView specific cell??? maybe is a textbox overlay value cell while numpad control is shown??  some ideas???
    bye Ema!
