FTP but not Controller
First I will explain my situation:
+ I have latest RS without license and expired.
+ First I connect to the service port and I can not even connect to FTP then I change IP like the picture below and it works with FTP server.
And then I scanned the controller, but I never find it. My robot's configuration is :
Prepared selection(s):
Serial no 14-26752
0927 System Pack 4.0
Selection(s) setup from 3HAC6811-2.21
39-1 BaseWare OS
413-1 English
IRB type 1400
1400 Y M2000
No Ext Axes
148-1 FactoryWare Interface
8-1 Advanced Functions
230-1 Multitasking
193-1 IO Plus
I scanned both by using RS and network scanner. Is there any chance because my RS is expired.
  • Hi
    Can you please explain how this is related to RAB? Isn't this question better asked in the Robot Studio part of the forum?
    Lennart H
  • This is probably due to Firewall/Security settings on the PC. There are other forum topics on this and also an instruction in the Release Notes.
  • Hi,
    RobotStudio 5.xx only supports IRC5 controllers. Judging from your options list, it seems that you have a S4, S4C, or S4C+ system ("System Pack 4.0"). You will be able to use FTP, but there is no tool similar to RobotStudio 5.xx available for S4, S4C, or S4C+ controllers. The exception is RobInstall which is used to create and download a new system to the controller.
    ABB
