FTP but not Controller
vinhvo
First I will explain my situation:
+ I have latest RS without license and expired.
+ First I connect to the service port and I can not even connect to FTP then I change IP like the picture below and it works with FTP server.
And then I scanned the controller, but I never find it. My robot's configuration is :
Prepared selection(s):
Serial no 14-26752
0927 System Pack 4.0
Selection(s) setup from 3HAC6811-2.21
39-1 BaseWare OS
413-1 English
IRB type 1400
1400 Y M2000
No Ext Axes
148-1 FactoryWare Interface
8-1 Advanced Functions
230-1 Multitasking
193-1 IO Plus
I scanned both by using RS and network scanner. Is there any chance because my RS is expired.
Can you please explain how this is related to RAB? Isn't this question better asked in the Robot Studio part of the forum?
Lennart H0 -
This is probably due to Firewall/Security settings on the PC. There are other forum topics on this and also an instruction in the Release Notes.John
Developer Center0 -
Hi,RobotStudio 5.xx only supports IRC5 controllers. Judging from your options list, it seems that you have a S4, S4C, or S4C+ system ("System Pack 4.0"). You will be able to use FTP, but there is no tool similar to RobotStudio 5.xx available for S4, S4C, or S4C+ controllers. The exception is RobInstall which is used to create and download a new system to the controller.Henrik Berlin
ABB0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
