Robot Target
fertil
in ScreenMaker
- Could we have access to each part of a Robot Target.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
For example, I want to be able from the screen maker application to modify the x of the position.
For the moment we can only read all the position. I want to be able to read each part of the position.
PERS robtarget PlacePos := [[-1001.54,1310.01,-203.19],[0.00396662,0.711024,-0.70311,-0.00811001],[-1,0,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,0]];
It?_Ts not possible to read the X directly from the screen maker. At the moment we have to use some rapid program to be able to read the value.
Modifying Rob Targets is not supported in ScreenMaker due to safety reasons; it is only possible to read the values0
[QUOTE=SriniP]Modifying Rob Targets is not supported in ScreenMaker due to safety reasons; it is only possible to read the values[/QUOTE]
How is it any different then using Hot Edit? Other then possible restrictions in hot edit, but couldn't those be applied into the ScreenMaker as well?
Dustin0
- 367 IRC5
- 858 RAPID Programming
