Declare dynamic array or change array size
I need to define an array with a dimension that is previously calculated:
PROC myprogram(num arraysize)
VAR num myarray{arraysize};
RAPID returns an error saying arraysize isn't a constant. So is there any possibility or workaround to achieve that? Or is there even an instruction to append dimensions to an array?
Regards,
Michael
Regards,
Michael
Varibles cannot be dynamically allocated during run-time in RAPID. What you can do is to declare the array to be large, 128, say. And then use a num variable to point out the last valid element. Something like this perhaps[CODE]MODULE apaCONST num maxarraysize := 128;VAR num myarray{128};VAR num arraysize:=0;VAR num currentarraysize:=0;PROC main()initarray;insertelement(2);insertelement(45);insertelement(673);printarray;ENDPROCPROC initarray()currentarraysize:=0;ENDPROCPROC insertelement(num element)currentarraysize:=currentarraysize+1;myarray{currentarraysize}:=element;ENDPROCPROC printarray()FOR i FROM 1 TO currentarraysize DOTPWrite "Element myarray{" + NumToStr(i,0) + "} = " + numtostr(myarray{i},0);ENDFORENDPROCENDMODULE[/CODE]Henrik Berlin
Hello @Henrik Berlin or anyone else,
I am facing exactly the same problem.
It seems like it is still the same 15 years later, but has a new workaround been developped since then ?
Is there any alternative anyone konws about, except from oversizing the array at the beginning ?
Hi...When the encounter is a problem I use Array as a parameter...See the example to read the file...
PROC FileContentRead(INOUT string contentP{*},string pathFileP) ! ## ATTRIBUTES ########################################################################### VAR iodev fileIodevReadL; VAR num indexL:=1; ! ## ATTRIBUTES ########################################################################### ! Open the file for Writing... Open pathFileP,fileIodevReadL\Read; ! Iterates through the array for reading... WHILE indexL<=Dim(contentP,1) DO contentP{indexL}:=ReadStr(fileIodevReadL\RemoveCR\DiscardHeaders); Incr indexL; ENDWHILE Close fileIodevReadL; RETURN ; ERROR ! ################################################ ######################################### ! HANDLING OF POSSIBLE ERRORS ! ################################################ ######################################### ! If an error is found, it displays a message and exits the program... IF ERRNO=ERR_FILEACC THEN ! Clean the screen... TPErase; ErrWrite "ERR_FILEACC","Error reading file" \RL2:="An error occurred while reading the parameter file." \RL3:="Action:" \RL4:="Check the file syntax."; ! Close the file. Close fileIodevReadL; Stop; Stop; EXIT; ENDIF ENDPROC
Good Works.0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
