Still problem with robhold wobj.
There is still problem with robhold wobj.
If i move a robhold wobj in RS it wont update the coordinates in the program. I can sync to VC severel times, shot down controller and then sync again, and sometimes it update sometimes it wont. The error have been in RS since the release of 3.0 and i have writen about it before. If i move in X,Y or Z i update manuel in programaker but if i rotate i have to enter Q1-Q4
Just a note.
I have learned to live with it. It's 2 years i found the error.
Best regards Klaus.
Klaus Soenderhegn
www.cadalysator.dk
Forgot to tell that the problem is the same if i move a fixed tool.
If i move to target it use the old posision byt if i jump to target it use the new posision. If i look in programaker the Const value is the old.
Then i enter the value manuel and it works.
Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
I just found out that if i change to anoter tool in my path, sync to controler and then change tool back to the first that i moved and sync again it works.
Strange
Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 367 IRC5
- 858 RAPID Programming
