Controlling simulation using analog values
Laro88
I can get / set digital values easily, however i need to model some digital inputs based on the setting of digital outputs.
I don't see the analog values in the Simulation->Event Manager Add ... screen, only digital ones.
Is this at all feasible....
Laro88 - now on XP and no severe crashes yet :-)
The event manager only supports analog station signals, not analog system signals.
Bugger, I have some external hardware that is controlled using an analog output, and a digital input that is the real world reports activity back based upon the state of the external hardware.
Hope you find time to integrate analog signals into the simulation. Meanwhile I will try to find a workaround.
- 858 RAPID Programming
