can't creat mechanism
Hi:
  In recent project,we want to creat a three axes robot carrier. First I creat three boxes using the Solid/Box Button
in the Modeling tab.Then I Open the "create mechanism window ",give the mechanism a name like "Gantry XYZ" and select
the mechanism type"External axes".
  When I finish all the setup , all icons are green. I can't find the "compiling mechanism" button. Besides there is
no scroll bar in the "create mechanism window". It should have.
  Pls help me? what's wrong with robotstudio?
  • Hi, you may try to increase your display resolution. RobotStudio requires at least 1280 x 1024 pixels.
    You may also reduce the size of the output window (or close it completly).
    BR
    Volker
  • Thank for your help.It's OK now.
