How can I change screen titles?
I'm trying to make my first screen with ScreenMaker 5.12.2040.0 and I can't change the screen title because it is blocked. (A padlock is showed and the properties are in grey)
I could see in SCM_ExampleProject that the titles are changed, but I can't change them.
Any one could help me?
Thank you very much.
GuGa
  • Hello,
    You can change the title for every screen present in ScreenMaker.
    You can click on the Screen for which the title needs to be changed from project treeview ( for example MainScreen).
    On doing this "The ScreenMaker : Properties window" will show the screenForm control selected. The Text property of screenForm can be changed for displaying the appropriate title.
  • Thank You very much!
    I did it on the wrong way!
    GuGa
