Using UIshow with Screen maker
I want to call my screen maker program from rapid with UIShow ins.
but i get "Typename is invalid for this assembly error".
My code is below .
CONST string Name:="TpsViewUserInterface_928.dll";
CONST string Type:="ABB.Robotics.sdk.Views.TpsViewUserInterface_928";
VAR num mystatus:=0;
UIShow Name, Type Status:=mystatus;
i see type error  (status=-5).
My dll files names are :
TpsViewUserInterface_928.gtpu.dll
What i need to write as typename to use UIShow Command with Screen Maker?
Thanks.
HnmN
  • Hello,
    Kindly refer to this post :
    If your are not able to access this link then the Type should be ABB.Robotics.sdk.Views.MainScreen. Try this.
  • First thanks for your helps.
    I ve tried as below but it is still not working and giving the same error code :(
    CONST string Type:="ABB.Robotics.sdk.Views.MainScreen";
    HnmN
  • Hello,
    The name should be a gtpu dll.
    CONST string Name:="TpsViewUserInterface_928.gtpu.dll";
    The typeName should be
    ABB.Robotics.sdk.Views."MainScreen as defined in ScreenMaker"
    Any screen in ScreenMaker can be made as MainScreen.
    So if "UserInterface_1" is made as (main) in ScreenMaker, then type name would be
    CONST string Type:="ABB.Robotics.SDK.Views.UserInterface_1";
  • Hi,
    Thank you very much. Now it is working. :)
    Is it possible to open a screen that isnot set as Main?
    HnmN
  • Hello,
    It is not possible to open a screen that is not set as main directly without performing any action from the mainscreen.
  • OK.Thanks.
    HnmN
