Assign system to existing file
Hello at all!
I got a few stations with already programmed motions......
Now i found out that they got the wrong system.
I already created the new system as i need it with the system builder.
But now i cannot assign this system to the already existing files!?
I already tried to copy the paths and the workobjects into a new file (file with the new system), but that did not work.
So if anybody could help me with that, would be great!!!
Thank you!
  • Hello,
    If you have the programmed motions saved as targets and paths in the stations, you shouls synchronize the paths to the new VC (system). If you have saved the motions as rapid code you can load in the rapid modules into the new VC from the Offline tab, or restore the backup (if you have one from the old system).
    To avoid that you get the wrong system in the future I recommend that you use "Pack and Go" which saves both the station and all systems used in the station.
    ABB Robotics
  • Thank you!!
    I copied the source code into the new file with the new system and did finally some adjustments.
    It works!
    But now i got a new problem, which i wanna post as a new topic.
