Problem whit connection
Palko
im trying to upload backup from robot. So i have build system and open it.
Controler starts to connection but dont connect just still trying until i shut it down.
I get no error mesage so i dont know whats wrong.
Have anybody some idea?
Thnks
Have you tried using the "Go Offline" feature of the Online tab?Do you have the same RW version installed on you PC as running in the real controller?Do you have a programming with an infinite loop running in any of the background tasks of the backup, e.g. to check some I/O conditions? A WaitTime 0.1 anywhere in the loop will give the VC time to breath.What you can do is to create a similar system with the System Builder (system from backup option)Then load the programs and cfg files separately, one by one to detect what is causing the problem.Henrik Berlin
ABB0
- 858 RAPID Programming
