Unloading AddIn causes crash
I'm writing a C# AddIn that receives collision events.
Every time the plugin is loaded and unloaded, each new collision event causes an unhandled Exception in RobotStudio. Re-building the AddIn causes the same problem.
Only resolution I've found after several days is to restart RobotStudio.
Crash report and source code attached.
webwiz/3224/ThisApplication.zip
webwiz/3224/RobotStudioReport_2010-0111_105127.zip
  • I should probably point out that the AddIn works on its own, and that it's pretty much cut-n-paste from the documentation examples.
    erikjber2010-01-11 14:40:00
