Import of .RLB files
I just downloaded RS5.12.03 and found that it is not possible to import .RLB files anymore!. I have a huge collection of standard compents that IA've collected over the years, in the old .RLB file format.
Is this a known bug?
Anyone that knows a way to get around this??
/Kurt
Hi Kurt,it should be possible from Home Tab, Build Station Group.Press the upper part of the Import Library split button and a file dialog shall appear where you can select *.rlb as file type.Keyboard shortcut Ctrl+J.I dont have a .rlb file right now so I have not tried it myself.In case you find the dialog but the import actually fails, then its a bug.0
I have tried with a .rlb file and it works fine with my RobotStudio 5.12.03.Anyone else that have had this problem that Kurt encountered?0
Problem is solved according to customer.Henrik Berlin
ABB0
