can't creat mechanism
Hi:
In recent project,we want to creat a three axes robot carrier. First I creat three boxes using the Solid/Box Button
in the Modeling tab.Then I Open the "create mechanism window ",give the mechanism a name like "Gantry XYZ" and select
the mechanism type"External axes".
When I finish all the setup , all icons are green. I can't find the "compiling mechanism" button. Besides there is
no scroll bar in the "create mechanism window". It should have.
Pls help me? what's wrong with robotstudio?
Hi, you may try to increase your display resolution. RobotStudio requires at least 1280 x 1024 pixels.
You may also reduce the size of the output window (or close it completly).
BR
Volker
Thank for your help.It's OK now.0
