IPC DeleteQueue, documentation flaw
Laro88
In the ABB RObotics IRC5 PC SDK the DeleteQueue has a flaw in the example....
There is no QueueId method available on the Ipc called QueueId ( it is now called GetQueueId(string name)
Example code:
Example code:
Controller c = new Controller()
int queueId = c.Ipc.QueueId("RABQueue");
if (c.Ipc.Exists(queueId))
c.Ipc.DeleteQueue(queueId)
I have moved this thread to the RAB forum.BR frpa0
Hi,thanks for noticing. The example shall use GetQueueId. This will be corrected.0
- 350 IRC5
- 848 RAPID Programming
- 22 AppStudio
