Random value needed
Is there a way to get a random value in RAPID?
I need it to introduce some "noise" in the control of a motor...
Something like a float ranging from 0 to 1 with a flat distribution.
Regards
  • Hello,
    No, there is no function to generate a random number in RAPID, so you have to implement it yourself. Here is a suggestion, which seems to work reasonably well:
    LOCAL VAR num nSeed:=320;
    LOCAL VAR num nSeed_age:=150;
    LOCAL FUNC num Random(
    VAR num nSeed,
    VAR num nSeed_age)
    CONST num nModulus:=655;
    CONST num nMultiplier:=251;
    CONST num nIncrement:=13849;
    IF nSeed_age>140 THEN
    nSeed:=GetTime(Sec)*GetTime(Min);
    nSeed_age:=0;
    ENDIF
    nSeed_age:=nSeed_age+1;
    nSeed:=((nMultiplier*Abs(nSeed))+nIncrement) MOD nModulus;
    RETURN (nSeed/nModulus);
    ENDFUNC
     BR,
    frpa
  • Thanks for the suggestion, I will use that as a base and add some additional noise based upon the current robot position.
    Btw. I just skimmed the program. It looks like the nSeed can become 0 (when sec or min =0) and this will result in extended periods of returning nIncrement MOD nModulus.
  • You are right! The seeding needs to be redone so that the seed cannot be 0. Thanks for pointing that out!
  • Here is a random generator, extend as needed.
    It uses 2. "random" seedings ( robot position, time) and a counter + Cosinus to generate a nice random number...
    Wink Please note that I haven't bothered to check for the "flatness" of the random distribtution - so this is most likely not TRUE random.
    MODULE RandomTesting
    VAR num callCount;
    FUNC NUM RANDOM()
    VAR num val:=1;
    var pos pos_current;
    pos_current := CPos(Tool:=tool0 WObj:=wobj0);
    !1 seeding, Seed by position
    val:=val*(Abs(ROUND(pos_current.x*100,Dec:=0)) +1); !+1 to avoid mul by 0 scenario
    val := 789 + val MOD 1000; !777 is just a bogus valu, since the mod might give 0
    !Feel free to seed with y,z, more
    !2. seeding, Seed by time
    val :=val * ( GetTime(Sec)+1);
    val :=val * ( GetTime(Min)+1);
    !3 seeding, increment callcount and handle large nuber
    callCount := callCount +1;
    IF callCount > 1000 THEN
        callCount := 234;
    ENDIF
    !finally a division to get something interesting large float number
    val := val / callCount;
    !get a value between 0 and 1 using COS ( math)
    RETURN (0.5 + COS(val)/2);
    ENDFUNC
    !Testprocedure, dump a couple of numbers to the logfile
    PROC TESTRANDOM()
    var num arandom;
    var string txt:="";
    var num count:=0;
    WHILE count < 18 DO
        arandom := RANDOM();
        txt:=txt + ValToStr(Round(arandom,Dec:=1)) + ";"; !Excel importable
        count := count+1;
    ENDWHILE
        ErrWrite I,"random values",txt;
    ENDMODULE
  • frpa!
    I tried your RandomGen, and it works sucesfully!
    But i have one question for you, how/can i decide the highest number i can get, ex no number higher then 200?
    BR
  • the simplest is to call random and save it in a num variable, and then multiply by your max number.
    Simple pseudocode:
    var num MAXNUMBER:= 200;
    var num rand = RANDOM();
    var num newrandom := rand * MAXNUMBER; !This gives you from 0 to 200 random
  • Updated RAPID code & tested it
    MODULE RandomNumber
    VAR num callCount;
    !Get a random number between 0 and 1
    FUNC NUM RANDOM()
    VAR num val:=1;
    pos_current := CPos(\Tool:=tool0 \WObj:=wobj0);
    val:=val*(Abs(ROUND(pos_current.x*100, \Dec:=0)) +1); !+1 to avoid mul by 0 scenario
    val :=val * ( GetTime(\Sec)+1);
    val :=val * ( GetTime(\Min)+1);
    !3 seeding, increment callcount and handle large number
        callCount := 234;
    ENDIF
    ENDFUNC
    PROC TESTRANDOM()
    var num arandom;
    var string txt:="";
    var num count:=0;
    WHILE count < 10 DO
        txt:=txt + ValToStr(Round(arandom, \Dec:=4)) + ";"; !Excel importable
        count := count+1;
    ENDWHILE
        ErrWrite \I, "random values",txt;
    ENDMODULE
  • Nowadays you can use Rand().
    David
    Swedish freelance ABB robot programmer
    Can you give an example? I am not finding much in the documentation.
  • See attached extract from the RAPID manual
    Rand.pdf 825.8K
